quick question on engine oil
Old Sep 28, 2007 | 10:13 AM
Bliss@5200's Avatar
Default quick question on engine oil
I just changed my oil and i put 5W30 in becuase i assumed it was the same as my rsx. Anyways the cap says 10W30. Should i have anything to worry about?
Old Sep 28, 2007 | 10:21 AM
__redruM's Avatar
I wouldn't worry about it. Next oil change, use the right oil. Also, be gental on the car when it's cold. The first number 5 vs 10 is the cold oil weight. So the oil is only different when it's cold. It's the right weight under normal engine temps.
Old Sep 28, 2007 | 10:28 AM
Bliss@5200's Avatar
alright thanks for the info
Old Sep 28, 2007 | 12:05 PM
neoarroyo's Avatar
If I remember correctly, a 5W weight has a broader weather range. As in, you can operate the engine in colder or hotter weather than say 10W...or is it the other way around?
Old Sep 28, 2007 | 12:43 PM
JS2k.com's Avatar
Sponsor
Oops, oh well I live in Texas anyways.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Sep 28, 2007 | 12:47 PM
Rdizzle's Avatar
Yes, you're right--the first number is how easily the oil can be pumped in cold weather while the high number is how thick it gets in hot conditions.
10W-30 is the recommended weight but you can always use other weights of oil as long as they meet the minium 10W-30 requirements. For example, 5W-30 is fine but DO NOT use 5W-20 (won't offer adequate protection after your engine's warm).
Old Sep 28, 2007 | 01:10 PM
rocrfella's Avatar
Use 5w-30 for colder places, otherwise 10w-30. I wouldn't be worried too much.
Old Sep 28, 2007 | 01:11 PM
Rdizzle's Avatar
Oh, and here's an excerpt from the owner's manual:
Old Sep 28, 2007 | 09:41 PM
Bliss@5200's Avatar
so in reality this is better for cold starts. Hmm Interesting. possibly a permanent change then.
Old Sep 28, 2007 | 09:43 PM
alejo's Avatar
you would benefit from the knowledge of the UTH guys on this one...
