Radiator Fan Problem
Old Mar 30, 2006 | 06:39 PM
Partshelper's Avatar
Default Radiator Fan Problem
Ok the fans kick on when the AC is on, and the fans kick on when I jump the fan switch line, and the fans kick on when I jump the Relays, but the Fan wont come on when I have it pluggen into the Fan switch? Why is that. Also I tried to plug in the fan switch to the Plug and heat it up with a heat gun to see if that temp would get it hot enough to start up the fans, but no go on that either. I then tried to replace the fan switch and try all the methods again, but still no go.. Someone HELP.
Thanks in Advance
Old Mar 30, 2006 | 06:47 PM
vtec9's Avatar
bad relay?
Old Mar 30, 2006 | 06:50 PM
but when I jumped the relays they all work, and all the fuses associated with this are all good..
Old Mar 30, 2006 | 07:36 PM
Slows2k's Avatar
Is the car stock, or are you using a EMS?
Old Mar 30, 2006 | 07:37 PM
xviper's Avatar
The tests you've done has isolated the problem to the fan switch or its ability to sense the coolant temp.
Using a heat gun on the outside of the fan switch may not be adequate to make the switch trip. The tip of the switch must reach at least 196 degrees. Testing it would require you drain the rad. Remove the switch and put the tip in boiling water. Then check for continuity between the two terminals.
You say you've put in a known good fan switch, so does this mean that you took the old one out and put a new one in? You actually drained the rad and filled it up again to do this? When you had each switch in your hand, did you confirm by the above test that they were OK?
Let's assume for the moment that the switches are OK. Something is wrong with the cooling system. It's not getting hot coolant to flow past the fan switch. You need to check why.
How's the coolant level?
Is the water pump working?
Is the thermostat opening?
Is the system bled properly? Was there work done to the cooling system lately?
Old Mar 30, 2006 | 08:33 PM
Got it working, WOOO HOO>. changed to a Mugen Fan Switch, and let it sit for about 6-10 mins and the fans came on.
Thanks for all your help guys, It was the fan switch.
Old Mar 30, 2006 | 08:45 PM
xviper's Avatar
So, you had TWO bad OEM switches? Whodda thunk?
Old Mar 31, 2006 | 01:57 AM
Yup 2 Bad ones.
But all fixed now. Thanks
Chugs
Apr 28, 2016 06:31 PM
aphex4000
May 28, 2015 03:44 PM
9kred
Jul 3, 2012 09:44 AM
Competitor9
Mar 21, 2011 08:39 AM
teecsS2K
Mar 21, 2010 08:12 PM
