Radiator Options?
Old Jun 30, 2004 | 12:26 PM
cjb80's Avatar
Default Radiator Options?
I have my car all torn apart now, and I have the coolant drained out. I figured now would be as good a time as any to swap radiators. What are the options available, and which is generally considered the best? I know of the Spearco and Koyo radiators, how do these two compare??
Thanks
Chris
Old Jun 30, 2004 | 12:50 PM
Voodoo_S2K's Avatar
Chris,
I've got the Koyo in my S and I've been happy with it so far. Fitment was perfect and the craftmanship is top notch. The radiator is a lot heavier than the stock one but roughly holds 50% more coolant. One item of note is that you can't use the stock radiator cap with the Koyo. It uses the older style cap.
Old Jun 30, 2004 | 02:41 PM
fperra's Avatar
Chris, while your doing the radiator, you ought to consider an air oil cooler if you don't have one already.
Old Jun 30, 2004 | 02:57 PM
f20kills's Avatar
Cbender
He had a good wright up on his C&R setup.
It might help you out.
Old Aug 11, 2004 | 06:37 AM
cbender's Avatar
Hi Chris,
I think the C&R setup is great -- although plumbing it took some time/patience. I'd highly recommend that you swap out your current oil filter relocation kit and block adapter for the CM parts -- www.cmfilters.com. Kevin at C&R was very helpful, the radiator dropped in as promised, and it's clearly a good (if expensive) solution to both high coolant temps and high oil temps.
Good luck,
CBender
CTECHs2k
Apr 26, 2011 03:55 PM
Sinan'S2000
May 31, 2008 11:44 PM
ideugene
Jan 9, 2006 05:16 PM
JohnsS2K
Sep 19, 2004 08:06 PM
Higgins
13
Mar 9, 2004 07:58 AM
