Radiator Pressure Question
We took it out to streets of willow, on the way up the car, started overheating, and pushing all the coolant into the reserve tank. When in the reserve tank it started boiling and trying to push out of the reserve. I let the car cool, and I checked the radiator, and it was low on fluid, so I filled it up and all was good for a second, then it started boiling again. and once the car was run on the track very lightly, same thing, the radiator would try to empty out, and push everything into the reserve. Trying to figure out what went wrong with it. The system was bled, fans kick on, People were saying head gasket, but I changed that less then 10000 miles ago. the bore on the head gasket is 89mm bore. The car is turbo right now. any help would be appreciated
can it be the radiator not flowing properly?
Headgasket is most likely suspect. There has been another FI S2k with a thick Cometic gasket blown.
Get a leakdown test done to confirm, a Gas analyzer probe placed over the radiator filler is a easy test, if you have the equipment.
You'll have higher HC's at the radiator than the tailpipe with a blown gasket.
