radiator thermostat
Old Jan 12, 2006 | 02:06 PM
QNZK1NGP1N's Avatar
Default radiator thermostat
how do you remove it?
Old Jan 12, 2006 | 02:51 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Follow the lower radiator hose to the engine. It goes to the water outlet, which has two bolts with 10mm heads. Remove the housing and the thermo is inside.
Note: Access will be very difficult. So will bleeding the air out of the system once you refill it. proceed with caution
rudyy
Sep 16, 2018 04:57 PM
myhui
Dec 6, 2013 10:39 PM
Fallen
Nov 21, 2010 08:25 AM
Spies
Oct 17, 2009 04:29 AM
QNZK1NGP1N
Jan 12, 2006 02:57 PM
