Random bogging/stalling
Old May 30, 2013 | 02:16 AM
AZ-S2000's Avatar
Default Random bogging/stalling
Driving around, I came to a light, car started bogging down, idling very low 100-300rpms, almost stalled. Kept fluctuating rpms until it finally stalled. I noticed prior to this, the rpms were a tad high idling In neutral, coasting to a stop. Than this happened. Where to start?
Old May 30, 2013 | 02:25 AM
AZ-S2000's Avatar
Forgot to mention, 01' with F22. No CEL either.
Old May 30, 2013 | 02:49 AM
SpitfireS's Avatar
Start with the MAP.
Whack it.
Really.
Search for MAP whack in the FAQ.
Old May 30, 2013 | 05:36 PM
AZ-S2000's Avatar
Originally Posted by SpitfireS
Start with the MAP.
Whack it.
Really.
I started it, ran good. Let it warm up to 3-bars and it still hasn't bogged down. I am going to clean the IAC anyway.
Old Jun 1, 2013 | 01:49 AM
AZ-S2000's Avatar
Cleaned the IAC really well, it has been idling much smoother and so on... BUT, it started bogging down again but this time it wasn't as severe as it was before. What else to check? MAP?
Old Jun 1, 2013 | 05:40 AM
plankfarm's Avatar
Maybe it's just heat soak?
Hot weather + A/C on = occasional bogging
Old Jun 1, 2013 | 04:37 PM
AZ-S2000's Avatar
No, its only done this at night actually. Bogging as in its idling 100-200 rpms and stalling too :/
Old Jun 2, 2013 | 04:11 AM
jl56tc's Avatar
try Some Throttle Body Cleaner... And Check Injectors... I KNow They Dont Fail Often But They Do Fail...Also It Could Just Be Your Fuel filter.. I Kno If You Have Heavy Sediment It Clogs the FilteR Partially Then Goes Away
Old Jun 2, 2013 | 03:18 PM
AZ-S2000's Avatar
What gets me, is that so far its only been doing this at night..
Old Jun 3, 2013 | 07:18 PM
jl56tc's Avatar
It'S Coinsadance
