RE : OEM Front Lip Install
Where can I purchase the WASHER BOLTS, CLIP NUTS, SELF TAPPING SCREWS, and SPRING NUTS that are needed for the install? I'll be purchasing a used lip and the seller doesn't have any of the necessary bolts, etc. Can I get them from any hardware store?
Thanks,
Bryan
Oh, I tried some dealerships and the ones that werent' closed said that they couldn't order them for me...for some odd reason...saying that "it was a kit and they can't do that.."
Thanks,
Bryan
I think that's crap. I was able to buy different pieces for the OEM alarm that comes in two seperate kits and each piece has it's own part number as I don't doubt the front lip kit does. I usually have them turn the monitor to where I can see it and point out the parts to them specifically. Most dealerships I have dealt with aren't very good at searching through the parts catalogs and can never find what I'm looking for until I kinda help point them in the right direction. If you can't find them from Honda, I'm sure that someone could give you the measurements of the hardware you need and you could buy it at a hardware store like you said. Bolts are bolts and washers are washers.
I was in the same boat as you when I got mine, no hardware included. I only bought 4 self-tapping stainless screws to hold the sides of the lip to the wheel well area. all other bolts are under the car, take them all off, put the lip on then put the bolts back on. then once you are satisfied with it's position, add the 4 side screws. mine fits like a glove with no problems this way.
S2KrNBRuIn
Aug 10, 2004 09:48 AM
payyourtoll
May 12, 2003 10:17 AM
