Really loose shifter
Old Apr 3, 2008 | 12:37 AM
slowpokeS2K's Avatar
Default Really loose shifter
just like the title states...i bought my car used and the previous owner told me that a short shifter was installed...
but its super loose. if i have it in first gear, i can literally move the shifter in a circle at about 2" in diameter from the top. what can i do to fix this?
Old Apr 3, 2008 | 03:52 AM
Skatethesea's Avatar
damn, dont know. Best of luck though
Old Apr 3, 2008 | 04:02 AM
Slows2k's Avatar
You could always buy a new OEM shifter.
Old Apr 3, 2008 | 04:48 AM
pgarratt's Avatar
Loose or worn bushings?
Pop the console and rubber boot off and take a look.
Old Apr 3, 2008 | 09:01 AM
Olegator's Avatar
there is a plastic plate inside that guides the shift rod, due to the short shifter it might have worn out prematurely...
Old Apr 3, 2008 | 03:20 PM
mister x's Avatar
Whoa that should been a red flag during the test drive. Probably not an expensive fix, just annoying. One of the great beauties of the S is the precision of the shifter.
Old Apr 3, 2008 | 03:22 PM
iam7head's Avatar
yes, all my friends said a thing or two about the shifter whenever i let them drive my pos
there's a plastic cap on the end of the shifter rod, it might be worn out or cracked.
it's a good time to lube up the shifter while you at it
Old Apr 4, 2008 | 10:26 PM
i noticed it and the seller was upfront about it...for the price i picked it up for, i didnt mind little things like this. thanks for the tips fellas....
Old Apr 5, 2008 | 05:02 PM
Adeeos's Avatar
Had this exact thing happen on mine after I modded the stock shifter,,, I cut the OEM shifter off about 1" above the pivot ball, tapped it to 1/2" 13,, threaded on a 1/2" coupling nut, and then fabricated a custom, shorter all stainless steel shift knob and shaft,, Now I can swap shift levers out to whatever I want,,, Anyway,, the small round nylon pivot ball on the tip of the lever split,, as well as the nylon, "cage" that the pivot ball rides in,,, I made a quicky new tip from a bronze bushing to get me by,, and yes,, there was a TON slop in the lever,,, I bought both a new tip cover, and cage,,, a whoppin $15 I think,,, made ALL the diff in the world!!,,, Just take a 10mm socket and extention with you to the dealer,, I asked for a small amount of bearing grease, and swapped them right there in the parking lot,,, Now it's TIGHT and firm shifts,,,
Old Apr 5, 2008 | 11:00 PM
do you mind letting me know the part numbers on those items? gonna stop by the dealer either tomorrow or monday...
edit never mind found a picture
is it number 7 and 8?
