Rear Brake Tool
I haven't done the brakes on my S2K yet, but on my other Honda I use a small adapter I bought at the local autoparts store. Looks like a small metal cube with protrusions and holes on each face. You insert the appropriate end for your car into the caliper and then use a ratchet to turn it.
UL
UL
I didn't know... I posted hoping to find the drill bit peice.
After people saything to use other tools, I went and looked. I posted to share what I had found.
I am still hoping someone knows where I can find the bit tho. If I have to do a mid-track day pad change, I would like to save some extra time.
If anyone is still looking for one, Snap-On has the bit for just under $20.
Tool, Piston Rotation - Stock NO:YA9329
http://buy.snapon.com/catalog/PRO_net.asp?...=snapon%2Dstore
I purchased a 3/8" socket to drill adapter at Sears.
It chucks into my Makita cordless drill, and will spin any 3/8" socket (or 1/2" socket with a standard adapter).
It makes taking tires on and off much easier...
I break them loose with a breaker bar, run the nuts off with the makita, run them back on with the makita (low torque) and tighten them with my torque wrench.
You could use the same adapter to spin that "hand" version you show, as it looks like it has a female 3/8" socket on the head. Would be nice if the handle was removable...
