Rear Brakes
Old Mar 19, 2012 | 10:49 AM
JacZilla's Avatar
Default Rear Brakes
Did a search on this, and I cannot find someone with the same issue.
Went out early this morning to try and get my pads changed. Got 3 corners really quick, but when I got to driver's rear, I ran into an issue. When I spin the piston inside the caliper, it doesn't retract.
Any ideas on what is going on?
Old Mar 19, 2012 | 10:53 AM
emdzey01's Avatar
Are you using arbrake caliper tool to turn the piston while compressing it back to sit flush against the caliper?
http://www.harborfreight.com/four-wh...ool-95713.html
Might also help if you loosen the bleeder valve on the caliper, but it can possibly introduce air into the lines.
Old Mar 19, 2012 | 10:57 AM
JacZilla's Avatar
No, I am just using a 3/8" drive ratchet with the caliper mounted on one of the bolts. I was pushing at the same time as turning.
Old Mar 19, 2012 | 02:02 PM
WhiteAP1ftw's Avatar
You really need to use a proper tool to do this. I used the kit that looks like this:
Old Mar 19, 2012 | 02:13 PM
SpitfireS's Avatar
Pushing (front) or turning (rear) caliper pistons back in with the bleeder open is always a good thing.
That way you do not push the worst and oldest brake fluid back in the lines.
(and you don't overflow the reservoir)
A hose on the bleeder, with the other end in a jar filled with brake fluid, will prevent air getting in.
It can take a while to retract the rear piston.
But you have allready done 1, so you know how many turns it took (roughly)?
Did you do the same amount of turns on the other one?
How far is that piston sticking out now?
Open bleeder, push & turn, it should work.
Old Mar 19, 2012 | 02:47 PM
JacZilla's Avatar
I've turned it a good 10-15 total rotations now. I'll try to open the bleeder and give it another shot.
s2000maniac
Mar 2, 2014 09:27 PM
erikvanden
Sep 9, 2011 12:44 PM
chilled
Mar 3, 2007 10:07 AM
ahbongkadah
Oct 12, 2004 01:11 PM
drewchie
Sep 1, 2004 10:07 PM
