rear piston is being a git
hi all
am after guidance
my rear near-side brakes had been sticking
after removing old pads i have been trying to wind in the piston.
it does not want to budge clockwise, it is stiff anti-clockwise too.
is there some part inside that might need cleaning and greasing?
any thoughts?
i am contemplating taking the assembly from the car to get better leverage. can anyone guide me on the best process for doing this please?
or is there a better way?
cheers Bert
am after guidance
any thoughts?
cheers Bert
if the piston is proving particularly stiff is there a likelihood of requireing the unit to e stripped and cleaned?
they were nowhere near this stiff last time I changed the pads. a large bladed screwdriver was adequate on that occasion.
can i use the brakes to push the piston all the way out, clean and grease and then replace?
I will also try a few tool places to make life easier when I do re-assemble
The threaded part (in red cirkel) is inside the piston.
The piston won't come out that far without leaking.
It should turn clockwise to retract.
bert_smith Posted on Jun 7 2007, 07:32 AM
Not without a full & proper brake fluid bleed
How about the hand brake (e-brake)?
The hand brake is off ... right?
hi
have been inundated
anyway
I took the assembly apart
the edge of the piston (part 18) has surface corrosion which was binding with the wall of the caliper housing (part 4)
I haev cleaned all parts and all seemed well, until the dust cover (part 19) had t be replaced.
you can just about get this into place but it refuses to remain in the groove in the housing.
have been inundated
anyway
ever since changing my rear pads myself it has been making a grinding noise when the rotors are cold. ocne the car warms up it's fine.
wonder what it could be?
even if i don't brake i can hear the grinding... it's a high pitched squeel like my brakes are out.
Chris S
22
Jan 27, 2003 04:11 PM
