rear wheel rubbing noise?
Old Dec 26, 2004 | 09:38 AM
ahbongkadah's Avatar
Thumbs up rear wheel rubbing noise?
First off, I hope everyone enjoyed thir christmas.
The problem i am having is that when driving on the freeway, or anytime above 45-50 mph, i hear this rubbing noise comming from the right rear of the car. It sounds as if the tire is rubbing on something, but i have looked and it is not making contact with anything. I replaced my rear wheel bearings about a year ago, i hope thats not the problem again (last time i didn't hear this noise).
Any ideas on what this may be?
Old Dec 28, 2004 | 05:10 PM
Anyone?
Old Dec 28, 2004 | 05:13 PM
Rino's Avatar
are you sure its not the tire? i mean you could have a parking break that is freezing up and its not really draging untill you hit a high speed
Old Dec 28, 2004 | 05:27 PM
Its for sure not the tire, i lifted the car and put it in gear. It was still making the noise, I also switched back to stock tires and the noise is still there. Actually its getting louder little by little. I am going to order another wheel bearing and hub again tomarrow
Old Dec 28, 2004 | 05:40 PM
Rino's Avatar
when it was up in the air did you try spining the wheel by hand? if so did it stick at all?
Old Dec 28, 2004 | 07:04 PM
No it didn't stick, that wheel spins free. I'm guessing its the bearing, I hope thats all it is.
Old Dec 28, 2004 | 07:15 PM
Rino's Avatar
sounds really funny to me i have never heard of one going out so soon. when you go to reaplace it try adjusting your parking break while your at it.
Old Dec 28, 2004 | 07:29 PM
Rino's Avatar
also after thinking about it if your wheel bering was going you should have some resitance when you are turning it. or you should feel it hang up.
Old Dec 29, 2004 | 12:21 PM
Thanks for all the advice Rhino. It helped me find another problem I've been having.
Turns out the rear left caliper is seized, and applying slight pressure all the time. But this was not making the noise, as it was coming from the other side.
So now I get to order a new rear caliper, new rear pads (they are not worn evenly with the seized caliper), and the right side rear bearing and hub
I was going to install my vafc and tune it, looks like this will be pushed back a little. There goes my christmas money.
As for the orig noise it is progressively getting louder. hopefully i can find time next week to get all this stuff replaced.
Old Dec 29, 2004 | 12:35 PM
RACER's Avatar
Is there a reason your replacing the caliper instead of rebuilding it?
