recomended fuel preussre?
Old Mar 31, 2004 | 03:05 PM
Slows2k's Avatar
Kane, The factory spec is the same 47-54 static, Which means engine running, vacuum hose to regulator removed and pinched to prevent a vacuum leak.
BTW, for everone using a Rising rate FMU (such as the Vortech) Your static fuel pressure will be higher due to the FMU adding a restriction to the return line. Mine was around 55psi with a Vortech FMU and stock regulator.
Edited for accuracy
Old Mar 31, 2004 | 03:23 PM
AusS2000's Avatar
NB: The Comptech FPR doesn't sit downline of the stock FPR like the Vortech. It completely replaces it.
Where the stock FPR sat you mount an adaptor and run a braided fuel line to the Comptech FPR.
Old Mar 31, 2004 | 05:52 PM
Slows2k's Avatar
Doh, I forgot the Comptech replaces the factory regulator.
Old Apr 1, 2004 | 02:31 AM
JO TECH's Avatar
I AM USED THE AEROMOTIVE FUEL REGULATOR 1-1 AND 680cc INYECTORS AND THE GREDDY E-MANAGE!!!!!!! 300 HP PLUS ASEGURADO!!!!!!
Old Apr 1, 2004 | 05:04 AM
Squeezer's Avatar
the helm manual says 320 - 370 kPa (3.3 - 3.8 kgf/cm^2, 47 - 54 psi)
Kitesurfer s2000
May 31, 2013 12:30 PM
NightStalker
Jan 11, 2006 04:50 PM
demonderrick
Aug 20, 2005 07:45 AM
