Recommendation for Replacement Alternator
Old Jun 28, 2021 | 07:14 AM
Lawdog's Avatar
Default Recommendation for Replacement Alternator
I have owned this car since 1999 and have had very few problems. It has 103000 miles. Lately it has not been charging the battery. I have replaced the battery but I think I need a new alternator. Can I get a recommendation for the best replacement and should I go new or rebuilt?
Old Jun 28, 2021 | 07:43 AM
Car Analogy's Avatar
A Denso rebuilt would be better than a generic new one. A new oem would be best.
But you are throwing parts at it instead of troubleshooting. If you are not able to troubleshoot, its often cheaper to pay a pro, since you won't go through as many parts before you happen to get the right one.
Troubleshooting charging system is as easy as getting a $10 voltmeter, and check battery voltage at idle. It should be getting around 14v-14.5v charge from alternator.
With engine off a healthy battery should be around 12.6v. At 12v its mostly dead. Those .6v make a huge difference. Of course, battery might read ok and struggle with a load, so a load test will really tell you if battery is ok. Most places that sell batteries will do this for free. Good to know for next time.
Meanwhile, check your charging voltage and get back to us. Maybe its not a charging problem but a current leak problem, where something is using juice even when car is off, draining battery. If so, an alternator would be a huge waste of money.
Old Jun 28, 2021 | 02:55 PM
Slowcrash_101's Avatar
Voltage regulator, rectifier, and brushes are what you need to overhaul it. Usually the bearing lasts.
Not hard to do at all.
Old Jun 29, 2021 | 01:47 AM
RolanTHUNDER's Avatar
My original is still good but I'd go this route when the time comes. I'd much rather source replacement Denso parts and keep the original alternator going than swapping it out for a generic.
fltsfshr
Feb 19, 2013 05:06 PM
cgutter
17
Feb 21, 2009 11:12 AM
Nicotunes
24
Jan 18, 2007 08:04 PM
