regarding suspension
Old Mar 30, 2007 | 03:44 PM
v2deLsoL's Avatar
Default regarding suspension
I have a couple of questions
Old Mar 30, 2007 | 04:32 PM
Borbor's Avatar
if it's a track-whore; then corner balancing is just using your tires fully. You can't corner weight a car unless it has adjustable spring perches (aka, coilovers)
On a clockwise track for example, you'd make more rights than you would lefts; so if you load up the right front a bit more than the left front, the amount of weight the laden tire sees during cornering would be less than if the front was perfectly balanced. This prevents you from overloading the front laden tire during cornering, and gives the tires a bit of a break; otherwise your laden front tire would wear out a lot faster than your unladen tire; it all depends on the nature of the circuit and whether or not you are willing to sacrifice the corners where you'll turn the other way.
edit: i realise i didn't answer question 1. Haven't had a chance to try it out yet. Fingers crossed I'm getting the car in a few weeks. So maybe in a few months, i can answer that question
Old Mar 30, 2007 | 06:45 PM
sahtt's Avatar
[QUOTE=hey_i'm_new,Mar 30 2007, 03:44 PM] I have a couple of questions
I<3myap1
Jul 2, 2015 07:31 AM
BlueS2000Boy
Jan 12, 2008 06:59 PM
Russian
Jun 23, 2004 01:57 AM
WestSideBilly
Jun 27, 2003 09:17 AM
