Reinstallin alternator
Old Jan 15, 2010 | 08:07 AM
dales2000's Avatar
Thumbs up Reinstallin alternator
Do you guys know of any tips to get the bottom of the alternator back into that tight space? I dont want to bang on it to get it in.
Thanks
Old Jan 15, 2010 | 08:24 AM
suzuka-blue-s2k's Avatar
Wish I could help more, but on mine I had to bang the hell out of it to get it in. Good to see your taking care of your car, but sometimes you gotta play the hard way.
Old Jan 15, 2010 | 10:09 AM
dales2000's Avatar
yea i kinda want to void hitting the alternator, i dont want to have to take it out again because i broke it lol
Old Jan 15, 2010 | 02:04 PM
charlonap1's Avatar
Use a steel brush or some sand paper to remove dirt and grime, then spray some wd40 on the brackets and it should just slide right in.
Old Jan 15, 2010 | 02:06 PM
charlonap1's Avatar
oh yea and use the bottom bolt as guide to help you position it correctly.
Old Jan 15, 2010 | 11:57 PM
s2k dre's Avatar
Just tap it with a hammer, it works everytime.
Old Jan 18, 2010 | 04:56 PM
dales2000's Avatar
thanks guys i broke down and gave a couple of love taps and in it went
Old Jan 19, 2010 | 03:49 PM
Tech7427's Avatar
lol
ive seen alternators come with the wrong bushings on the bottom bolt side, causing the alt. to not even slide into the bracket haha.
Old Jan 21, 2010 | 01:17 AM
iam7head's Avatar
lube and push
a little love tap on reinforced area of the housing can't hurt
Old Jan 21, 2010 | 06:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The alternator bottom bolt mounts in a floating bushing.
When you remove the alternator bolts, just tip the alternator forward with a bar and the bushing will move outwards.
Now you can just lift the alt out and in with ease.
