relocating battery?
Old Apr 30, 2009 | 09:51 PM
sbrodacz's Avatar
Banned
Default relocating battery?
I want to relocate my battery tomorrow. What is the best way to go about connecting a longer wire? Do I cute the current wire and then connect a new one to it? If so, what should I use as a connector?
Old May 1, 2009 | 06:56 AM
vtec9's Avatar
Don't cut anything! You need a battery terminal block so you can connect the old + wire to the new +. Should be available at local parts store. So you hook the old wire to the block, then run the new wire from the trunk through the firewall and hook it to the block. easy as pie.
Old May 1, 2009 | 07:51 AM
sbrodacz's Avatar
Banned
Thanks, do you think you can post a picture of it? I want to make sure I get the right thing.
gst19psi
Nov 29, 2014 05:05 PM
liquidgsr
Apr 7, 2013 03:43 PM
Gatsbee13
Aug 17, 2010 09:34 PM
macprotege5
Feb 28, 2007 09:27 AM
CIVICTOS2000
Aug 17, 2005 01:04 PM
