Removal of Convertable Frame/Motors
Buy a service manual, if you don't have one already. http://www.helminc.com/
It's all in there, in good detail. One hint that is not in the manual -- remove the seats first.
I was thinking of pulling an all nighter today because it seems as if Im not going to sleep well tonight.
Pop out the flood lights and start taking things apart. I have 2 days to put it back together : )
I pulled it all apart in about four hours, following the service manual. I really recommend the manual, because there are a lot of little hidden screws that are not obvious to find.
According to the Manual 20-35 through 20-39
On Convertable top replacement 20-38
Theres 4 sets of different types of bolts,nuts,and clips.
What I think might be difficult will be the Right and Left corner gusset
It looks kinda confusing
Originally Posted by BoostNhigh,Mar 14 2008, 09:09 AM
MikeGarrison - what was the most difficult part of the removal for you ?
The corner gussets are easy, once you have removed all the trim.
Also, don't split the covers over the roll hoops! It seems like you should, but they don't go back together. Lots of people make that mistake. (I can't remember if taking the roll hoops out is part of the job or not, but I know I did it at the time so I think it probably was.)
It looks confusing, but if you carefully follow the instructions it turns out to be fine. There are a few places where it says to remove X, then you look up X and to remove X is says to remove Y, etc. But like I say, follow all the instructions and it does work out.
If it says to remove X but it doesn't seem like you should need to -- remove X anyway! There were a couple times when I didn't follow the instructions and then learned I should have.
