Remove compliance bushing -- hack?
I need to get the compliance bushing out of the lower control arm, but... I don't have the proper size sleeve or a huge socket that would work.
Please tell me if this is a good idea. What if I press out the rubber, leaving the bearing outer race still in the arm. Then use a plate/disc thing from my bearing removal kit that is the proper diameter to push out that race, leaving me with that to then use to install the new bearing. Would that work? The problem is that this particular bushing has that centre shaft/whatever, which makes it impossible to just use the adapter plate to remove/install it obviously. I need a cup/sleeve of that size but don't have one. https://cimg2.ibsrv.net/gimg/www.s2k...3d72fe6a73.jpg |
Whatever works just don’t mess up the surface where the bearing sits, cut out the rubber and then cut the metal bushing sleeve out, should be able to push it out with a chisel easily, I was able to find a few pieces of exhaust pipe at crappy tire that worked great to push out the old bushing sleeve
i wouldnt do that :argh:
Originally Posted by noodels
(Post 25132846)
Why wouldn't you do it? |
Originally Posted by starchland
(Post 25132845)
Grr. I'll go to cdn tire and see if I can get some bits of exhaust pipe somehow. I've never done that before.. hopefully they will just sell me a few short pieces and one will work. |
(Post 25132851)
Don’t forget to index new bushing correctly
I actually am replacing with hardrace spherical bushings which I *think* can go in any which way. But I'll double-check, thanks for the reply. |
Originally Posted by 9KCanuck
(Post 25132853)
Do you mean orient it top/bottom correctly or maybe the arrow embossed in the rubber of the new one?
https://cimg2.ibsrv.net/gimg/www.s2k...fe5905ef98.jpg
Automotive section will have small pieces of pipe this worked great |
(Post 25132855)
this worked great If it comes to it, I found a cheap socket at Princess Auto that will also do the trick. https://www.princessauto.com/en/46-m...t/PA0008920340 |
Just support the arm around the bushing so you don't tweak anything, and just press it out. From my recollection it takes ~3.5 tons of pressure to push out the sleeve from the arm.
| All times are GMT -8. The time now is 06:30 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
