remove rotors?
Old Aug 10, 2005 | 11:50 AM
jasonw's Avatar
What can happen is that rust builds on the bottom of the screw where it sticks out on the back of the hub. If you go through brake pads fast enough and frequently remove your rotors for resurfacing, it should reduce the amount of rust that builds up.
Cobalt bit should take about 60 seconds to obliterate the screws though.
Old Aug 10, 2005 | 12:26 PM
Jasonoff's Avatar
Banned
I usually drill and replace them too.
Old Aug 10, 2005 | 01:38 PM
JohnE's Avatar
Out of curiosity, how much are new rotors? When I brake hard from 100-80mph I get some shudder.. I replaced the pads thinking they were worn, but they still had 25% remaining. I still get the shudder.
btw - I have used the impact driver and it stripped the screw, but this was on a Civic with 165k miles. Ended up drilling them out. Good advice on the cobalt drillbit.. I used a normal one and had a hell of a time.
Old Aug 10, 2005 | 01:44 PM
jasonw's Avatar
You can try just getting your rotors resurfaced/turned. That may do the trick or you can get some brembo sloted rotors in the group buy forum for around $310.
Old Aug 10, 2005 | 02:30 PM
JohnE's Avatar
What's the advantage of brembo over stock?
Old Aug 10, 2005 | 02:34 PM
jasonw's Avatar
You can get sloted and/or drilled Brembo rotors. Probably for around the same price as OEM...
Old Aug 10, 2005 | 02:54 PM
xviper's Avatar
Most likely your rotors are warped. Maybe from someone using an impact wrench to put your wheels on.
Old Aug 10, 2005 | 09:17 PM
RACER's Avatar
Bling, bling
Old Aug 10, 2005 | 09:36 PM
AusS2000's Avatar
Does that actually happen?
I know that what most people call warp is actually uneven wear due to some areas heat hardening more than others.
Old Aug 10, 2005 | 09:40 PM
jasonw's Avatar
I've also heard of the rears getting warped if you park with the e-brake after spirited driving(the area where the pads are touching may cool at a different rate).
