Removing AC
6 rib 45" long. If you give anyone at a parts store that they should be able to get you to correct belt.
Now, onto the other stuff. If you plan on removing the compressor you have to have it discharged professionally to comply with the EPA.
Also, if you get the CR belt you need to double check that it is the AC delete version. Some had AC.
Corey Maurer
Jun 11, 2013 04:59 AM
OneSilverS2k
Mar 22, 2011 08:52 PM
