Removing soft top
Old Oct 28, 2009 | 04:01 PM
tmkpres's Avatar
Default Removing soft top
I tried searching for it, and searched for it again before I posted this.
So here's the question.
Is there anywhere in this site that has a DYI on removing the soft top ? I got a HT and really doubt that I will go back to my soft top.
AGAIN if there is a thread on this already I didn't find it, sorry in advanced.
Old Oct 28, 2009 | 05:46 PM
Kdlopez01's Avatar
me too
Old Oct 28, 2009 | 08:10 PM
JDMQuip's Avatar
It's pretty easy if you have a general knowledge of tools and some patience. I suggest you have a friend help out too.
Basically you:
Remove the seats with 14mm and 17mm ratchet
Remove rear padding
Remove bolts that hold roll hoops but DO NOT remove the PLASTIC AROUND THE ROLL HOOPS. You will regret it in the end.
Remove clips from the soft top tray from BEHIND the seats and into the trunk. I found it easiest to remove the trunk carpet, spare tire and etc....
It's a bitch so be prepared.
Old Oct 28, 2009 | 11:08 PM
iam7head's Avatar
it's take some time, but once you get to it, you can see everything there.
i doubt you'll need a DIY for that, just take it easy with the plastic panel, those push clip can cost you about 30 buck, i broke couple of mine and honda wants my ball for it
Old Oct 29, 2009 | 08:37 AM
tmkpres's Avatar
Thats so stupid for those lil plastic pieces
Old Oct 29, 2009 | 08:49 PM
truancy143's Avatar
Here's the DIY link:
https://www.s2ki.com/forums/index.ph...T&f=1&t=448840
GL
i have to do this soon myself
Old Oct 29, 2009 | 09:41 PM
jdmgpw04's Avatar
if your ever going to take the hard top off make sure to take off the driver and passenger seats... to make everything easy...
first timers usually take at least 3-5hours...
Old Oct 30, 2009 | 01:41 AM
IHoP's Avatar
It seems hard but removing the top is the easiest part...putting a soft top back on is the pain in the ass part. I just changed out the soft top on my car last month. IMO more pain in the ass than changing a clutch on an integra which is kinda easy actually.
liquidgsr
Jun 6, 2012 01:36 PM
s2kc's
Apr 6, 2010 04:54 PM
Whoabitchin
Mar 23, 2010 12:52 PM
NexS2000
Jul 20, 2008 08:59 PM
EVAN&MONICA
Jul 6, 2008 07:26 AM
