Removing Stock Cat
Old Jun 17, 2012 | 01:46 PM
Jag528's Avatar
Default Removing Stock Cat
I just got my Berk test pipe in the mail today so I got the car jacked up to get it on but the nuts on the cat are so corroded that I can't even move them. I've tried liquid wrench and still nothing. Even if I break the nuts off I think the bolt thread might be too corroded to get a new nut on. Should I just cut out the whole nut and bolt assembly out and get a new set from the dealership? Any input is appreciated.
Here's a pic to show how corroded it is.
Old Jun 17, 2012 | 02:23 PM
ebony APWON's Avatar
thats how mine looked . i had to cut them off with a cutoff wheel and got new bolts
Old Jun 17, 2012 | 02:25 PM
User 111717's Avatar
Try PB Blaster, you can get it at your local auto parts store
Old Jun 17, 2012 | 04:09 PM
Jag528's Avatar
Looks like I'm headed to the dealer tomorrow. Might pick up a doughnut gasket for the header while I'm there just in case. I'm not sure that PB Blaster would work, it's basically one solid piece of metal.
Old Jun 17, 2012 | 05:34 PM
Ultimate_Combination's Avatar
Mines looked just like that when I did my Berk HFC install. I shot those rusted bolts with WD40 and some off-brand liquid wrench like 10 times in a 2 hour span..then used a breaker bar to take them suckers off!
Old Jun 17, 2012 | 05:54 PM
T-Smac's Avatar
Mine looked like that on my 01. You're going to want a new spring/bolt kit. No sense putting those back in (good chance they will snap before coming loose...mine did). I got each spring/bolt for 7 dollars from O'reilly Auto parts. Much better than the stealership I'm sure.
Old Jun 17, 2012 | 07:29 PM
downloader's Avatar
if the Pb blaster doesnt work you can try to heat them up with a torch
Old Jun 17, 2012 | 08:32 PM
singlespeed's Avatar
i used pb blaster on mine and tapped at them to break the rust loose. but they werent near that rusted
Old Jun 17, 2012 | 09:09 PM
john82389's Avatar
Do you have to use spring bolts or can you use regular bolts with lock tight? I know stock uses spring bolts but I just did this recently and had no problems...hoping that it stays that way.
Old Jun 17, 2012 | 09:30 PM
Curtis61's Avatar
It will work with normal bolt but I wouldn't. Spring bolts are there for when the exhaust flexes so it has room to move and bend without leaking.
