Removing TPS sensor
Old Mar 7, 2006 | 06:40 AM
GDM S2K's Avatar
Default Removing TPS sensor
How do I pop my TPS sensor out of my Throttle body?
Old Mar 7, 2006 | 07:23 AM
xviper's Avatar
According to the Helm manual, this is not to be done. If the TP sensor needs replacing, you replace the whole throttle body.
Old Mar 7, 2006 | 07:24 AM
GDM S2K's Avatar
I poped it out no problem. I needed to remove it for my new TB
Old Mar 7, 2006 | 07:31 AM
xviper's Avatar
So why'd you need to ask?
Let us know if it works. Honda must have had a reason for not swapping sensors.
Old Mar 7, 2006 | 07:42 AM
GDM S2K's Avatar
At first I wasnt sure how to do it But I figured it out
Old Mar 7, 2006 | 12:37 PM
Asura's Avatar
X, it does work. The issue is that Honda rivets them in place and the TPS has a max min voltage. If you re-install the TPS sensor on another TB, you will need to re-calibrate this max min voltage.
Old Mar 7, 2006 | 01:05 PM
GDM S2K's Avatar
Yea all we did was cut a slash into the rivet and took a flat head to get it out.....
Old Mar 7, 2006 | 01:42 PM
xviper's Avatar
deibit
Sep 5, 2010 07:48 AM
macr88
Engine
Jan 21, 2010 11:13 AM
DeadZero
Socal Swap Meet
Jun 18, 2009 07:16 AM
Spitlist
Mar 7, 2007 10:29 PM
Sideways
Nov 26, 2006 11:24 AM
