Removing the transmission
I've got all the bolts out and we've wedged a 1-inch gap in between the trans and the block (you can see the flywheel and internals of the trans), but I'm unable to fully separate the trans from the engine. Is there an internal shaft or something that's connecting the two???
It's apparently not that hard. You need to take off the starter, drop the subframe down a few inches (don't take it off) and then make sure to have a long ass extention for your socket wrench (36" if i remember correctly)
Yeah trans shouldn't be too hard (don't forget about the shifter, though! Center console is easy to remove - it literally just pops off)
We actually removed the whole engine without removing the transmission, and didn't even have to touch the subframe.
