Replace piston rings to fix AP1 oil consumption?
Old 06-19-2018, 08:07 AM
jyeung528's Avatar
if i'm not mistaken i believe the owners manual says 1 quart per 600 miles is okay.
Old 06-19-2018, 08:58 AM
s2000Junky's Avatar
No, you would be mistaken. Its 1000.
I actually took Honda up on it with a motor that was drinking 1Q every 800 miles. They tore down the motor and found what looked like some kind of casting cracks in the cylinder bores and chalked it up as manufacturing flaws so they replaced the short block under the extended Honda care warrantee I had at the time.
klapamos (08-16-2020)
Old 06-19-2018, 11:37 AM
Slowcrash_101's Avatar
Originally Posted by Billman250
If you dont hone/prep the cylinders, the new rings will not seat in. I guarantee your oil consumption will be even worse after a ring job without honing.
how much honing is needed? We talking ball hone or rigid hone with all the steps?
Old 06-19-2018, 02:52 PM
clio's Avatar
+1
Old 06-20-2018, 04:05 PM
s2000ellier's Avatar
When I built my F24 in my garage I took a complete long block down to every component and re-ringed the pistons that went into the same bore they had always been in. When I measured ring gaps in 3 places along the cylinder I had some taper but all I did was use a Wiseco nylon hone to prep the bores and used the 06+ piston rings. Car had no smoke/oil consumption problems up for 2 seasons until the point I went from 5 to 2nd at 100 mph at T1 in Sebring
The following 2 users liked this post by s2000ellier:
CTSV (05-31-2019), Slowcrash_101 (06-20-2018)
Old 06-21-2018, 07:51 AM
fatjoe10's Avatar
Can you describe the process a little more? (stroke speed, how many passes etc etc). I have seen your F24 build thread but this info was not clear. Thanks!
Old 06-21-2018, 03:56 PM
1400 rpm drill, 10 passes per bore. used ATF fluid, dosed the hone every 5 passes
my numbers sheet
https://www.s2ki.com/forums/automoti.../#post23886766
my worst bore taper was 0.015 inch at the bottom to 0.011 inch at the top
fatjoe10 (06-22-2018)
Old 06-21-2018, 04:41 PM
starchland's Avatar
I guess it depends on how bad the taper is in the bore
Old 06-29-2020, 02:33 AM
nolty's Avatar
So, did you manage to replace the rings?
Old 06-29-2020, 02:43 AM
fatjoe10's Avatar
My recent F24 build burns zero oil on unprepped cylinder walls and NPR chrome faced piston rings with good compression on PZX pistons. The repair manual doesn't ask you to rehone unless there are scratches or damage. I would re-ring that engine and hopefully the out-of-round condition isn't severe enough to negate the benefits of re-ringing.
Quick Reply: Replace piston rings to fix AP1 oil consumption?
