replaced coolant system.....
Old Nov 5, 2010 | 06:45 PM
osidis's Avatar
Unhappy replaced coolant system.....
well in preparation of getting a turbo kit, i thought i would upgrade the cooling system to support the extra heat. So, i went with mishimoto parts, radiator, hoses, stat, fans, and fan switch. i flushed the system completely with distilled water and then replaced it with 50/50 and added 2 bottles of royal purples engine ice. under normal operation, the temp gage was at 7-8 bars. mine is an ap2, my understanding is that 7-8 is the norm. however now it operates at 4-5 bars. so, is my system TOO efficient? i already reset the ecu and it did it again. so im a little worried now. i will check the code tomorrow. it doesnt retard my system either. any input would help. any ideas what caused it? and is i bad for my car?
i have an AEM version 2 ems, would this fix my issue if is is indeed my factory ecu that cant support my mods?
Old Nov 5, 2010 | 06:51 PM
zeroptzero's Avatar
double check your work to see if you left any hoses or sensors disconnected. I just replaced my rad hoses and I had to pull a handful of vacuum hoses and some sensors to access the tight fit of the engine bay. I'd bet the CEL is due to one of them, get a reading of the CEL to see what code it is. I doubt your CEL is due to the cooler temps.
Old Nov 5, 2010 | 07:14 PM
osidis's Avatar
thanks. i hope so
Old Nov 5, 2010 | 07:22 PM
S2K-F8's Avatar
OP you might want to search around. I remember a thread about engine temps and cooling systems and from what I remember you can actually be running too cool.
just found it
cooling
Old Nov 5, 2010 | 07:27 PM
S2K-F8's Avatar
Got this from Modifry's website. It shows the ~ temp for each bar on the AP2 cluster
If you are only seeing 4 to 5 bars I would say you are running too cool
Old Nov 5, 2010 | 08:48 PM
osidis's Avatar
wow, thanks.
Old Nov 5, 2010 | 09:46 PM
realblag's Avatar
Get rid of the mishimoto thermostat and get a Honda oem one. If your engine is not coming up to normal operating temp, check the thermostat first. Also, I doubt the Engine Ice will be needed.
Old Nov 5, 2010 | 11:02 PM
ahrmike's Avatar
I run a mishi with no problems as do countless other people..
OP, its most likely due to your lower temp opening thermostat. You should just reinstall the OEM t-stat and you'll do fine. Running lower temp t-stats wont help the car keep cooler, it just slows down the speed it takes to hit higher temps... (aka, not letting you hit operating temp).
Actually, 4-5 bars sounds about right, I know a lot of lower temp t-stats open at 160 or 180F... Get the OEM on there and you'll definitely be good to go, even with your turbo.
---edit---
as for the CEL, its most likely due to something other than your cooling, as JFusion said. Pull the codes!
Old Nov 6, 2010 | 04:27 PM
zeroptzero's Avatar
I just started up my car after swapping out the coolant hoses and got the CEL code 1597 on start-up, was for the idle air control valve. No idea how it was triggered but I cleared the code and will monitor it. I removed the IAC to make more room for the hose swap and put it all back together according to specs.
Old Nov 7, 2010 | 08:15 PM
realblag's Avatar
LMAO...you quote me and give a confused and a thumbs down....and then say the same thing....nice
