Replacing the actual shifter
Old Mar 27, 2009 | 03:16 PM
ryanmatic's Avatar
Default Replacing the actual shifter
I apologize in advance if this has already been answered; I did a couple of searches and came up with nothing.
Does anyone know of DIY directions for replacing the stock shifter (not the knob, but the actual stick)?
I bought my car used and it came with an aftermarket shift knob (a crap one, too). I was planning to install a titanium Team Voodoo one today, but after wrestling with the current knob for about two hours I don't think I can. I got the crappy one off but am now left with a shifter that's got lots of rust and hardened (sturdy) glue residue in the threads.
WD40, steel wool, and a razor blade all haven't cleaned it up enough. I went ahead and ordered a new shifter from the local dealership and it should be here on Monday. If the replacement is straightforward I'd rather handle it myself than have the dealership do it, but I can't find instructions. I looked in the S2000 manual too and came up empty.
Old Mar 27, 2009 | 05:35 PM
mister x's Avatar
http://www.ricks2k.com/info/instructions/A...hortShifter.pdf
Just be careful when taking off the white plastic ring around the rubber boot, it's held in by 4 tabs that need to be pressed outward from the shifter. Prying it up the way illustrated will break them.
Old Mar 27, 2009 | 06:01 PM
ryanmatic's Avatar
Awesome. Thank you for the link--this is exactly what I had in mind.
I'll make sure not to pry as illustrated, too.
Old Mar 28, 2009 | 04:28 AM
SpitfireS's Avatar
And use enough grease.
IMO one can't use too much grease there.
Well.. if the shifter doesn't fit in anymore.. maybe.
Old Mar 28, 2009 | 11:43 AM
ryanmatic's Avatar
Okie dokie. I'll keep that in mind. Thanks
Old Mar 28, 2009 | 01:55 PM
PWRMKR's Avatar
I would have just bought a die and chased the threads. But that
Old Mar 28, 2009 | 11:20 PM
ryanmatic's Avatar
Thanks hecash, that detail is very much appreciated. It sounds like the grease and the careful removal of the boot retainer ring are pretty critical, though I'm concerned about the pivot ball and the cage...if they're cracked, does that become noticeable when driving?
[QUOTE=PWRMKR]I would have just bought a die and chased the threads. But that
Old Mar 29, 2009 | 07:10 AM
ryanmatic's Avatar
Gotcha. Thanks again.
Old Mar 29, 2009 | 09:50 AM
PWRMKR's Avatar
I believe the die would be a nominal diameter of 10 (mm) and a pitch of 1.25 (mm)
I
Old Mar 29, 2009 | 12:47 PM
sola77's Avatar
Honda shift rod thread diameter and pitch are 10mm x 1.50. A decent dye should work like a charm.
