replacing axles
Old Aug 7, 2011 | 01:00 PM
ap2s2kbrad's Avatar
Default replacing axles
Hello guys,
I was wondering if anyone on here has used auto zone axles. The reason i ask is because my axles i think are pitted i am lowered a 1 inch on tien s springs and under acceleration it feels almost as if i have a flat tire or and hitting on of the markers on the road over and over again. If any one knows what this is or if i should just go ahead and get new axles.
Old Aug 7, 2011 | 04:03 PM
JUSTINTHECOASTIE's Avatar
Spend your money on whats been proven to work, if your stock axles are toast, you should upgrade them...gator axles and driveshaft shop have axles for our cars that have been proven to work, good luck-Justin
Old Aug 7, 2011 | 05:07 PM
ap2s2kbrad's Avatar
Thanks justin i will check them out.
Old Aug 8, 2011 | 06:12 AM
Chugs's Avatar
Just swap your cv's side to side or get axle spacers, that should solve your problem.
Old Aug 8, 2011 | 08:31 AM
kenta's Avatar
+1
Yeah, swap the buckets side to side. It's cheap, it'll only cost you the price of the grease if you do it yourself since you can re-use everythingelse including the bands. And, once you'll get them apart you will be able to confirm they're pitted. Or, if you can get spacers cheap that's a good option. Even a set of rebuilt axles will be $300+.
Old Aug 8, 2011 | 09:45 AM
This is a temporary fix, however to never worry about it again you need to replace
Old Aug 8, 2011 | 11:41 AM
ap2s2kbrad's Avatar
I will look into switching the boots until i get the money to get better axles what grease do i need to use. Does any one on here have experience with drive shaft shop axles or this gator axles that Justin talks about.
Mclovin54
Feb 6, 2016 02:56 PM
f23power
May 24, 2012 05:42 PM
myslows2k
Apr 21, 2010 07:19 PM
Rain
Jan 25, 2008 05:39 PM
mmbonbons
Aug 6, 2006 11:24 AM
