Replacing cams and caps
Old Oct 1, 2012 | 10:49 AM
blks2k06's Avatar
Default Replacing cams and caps
hi guys just wondering when replacing the cams and caps torquing them down correctly anything else i should check or do besides making sure the timing is correct? i just replaced the intake cam due to lack of oil circulation and it seized, then it happened again after driving it a couple of days, had problems starting having to jump it when it read a good battery... thanks
Old Oct 1, 2012 | 11:06 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'd check your oil passages...some of them are very tiny.
If the cam caps are not a 10 piece matched set (upper and lower), you will continue to destroy them.
Old Oct 1, 2012 | 12:33 PM
blks2k06's Avatar
yup they were a matching set from a 2007 s2k, put them on my 2006 s2k and ran fine then just stop completly on the free way, turned the motor and didnt see the intake came turning along with it. i dont want to keep on replacing this cam.
Old Oct 1, 2012 | 01:38 PM
Billman250's Avatar
Top Answer: 1
You have a serious defect somewhere.
Old Oct 1, 2012 | 02:02 PM
blks2k06's Avatar
with the 2007 caps? i know they have very small holes lubricating the cam lobes that are covered in the cap its self....ill will take a look and take off the valve cover see if i can get some pics...
Old Oct 2, 2012 | 05:03 AM
Billman250's Avatar
Top Answer: 1
I dont think its the caps...you had failure with other caps too yes?
Old Oct 2, 2012 | 08:10 AM
blks2k06's Avatar
the first caps yes, and 2nd yes.... some debris from the stupid spark plug not being tight enough one #1 piston got into the valve train (plastic shavings) and i think plugged up the cams oil flow the first time... now redid all the cams and caps and still seized like the alluminum from the caps melted into the cams the first time wich made me think i was lack of oil or plugged up somewhere...
Old Oct 2, 2012 | 08:13 AM
Kyushin's Avatar
Banned
Matched set? I just bought a used AP1 head from a dude here in socal and want to use the caps on another head that is rebuilt and will WPC the journals. Its ok to use diff cams or should I use the ones that came with the head?
Old Oct 2, 2012 | 09:44 AM
4forall's Avatar
I would think if a cam seized up two times and stopped spinning while the motor was still going your going to tear up more than just cam caps. As well as the cause just chewing up more cams.
If the caps are all from the same head it is fine to use them in a different head. This is from what i understood reading others talking about the issue.
Old Oct 2, 2012 | 09:52 AM
MM3Kwolik's Avatar
Cam holders need to be matching uppers AND lowers, otherwise you will most likely have issues. They are all different, you cannot just take a set of caps and use them on a different set of lowers. It doesn't work that way. Honda machines the cam holders bolted together as a set. Not one set is alike.
