Replacing Drive Belt....is there a how-to?
I have a 02 with 65K miles and was wondering if there was a writeup on how to change the drive belt, and where is the cheapest place to get the belt?
Btw, I tried using the search but I didn't find what I was looking for.
TIA
TIA
Originally Posted by Slows2k,Nov 2 2005, 09:47 PM
It's pretty simple. Take a 14mm wrench and put it on the tensioner bolt, pull the tensioner away from the belt, and take the belt off. Re-route the belt like it came off.
TIA
TIA
Is it in bad shape? I've got nearly twice as many miles and I'm still on the original belt. I had it off the other day while replacing the thermostat and it shows virtually no signs of wear or cracking.
Originally Posted by piecesofcurb,Nov 2 2005, 09:31 PM
Why are you replacing the belt with only 65,000 miles on the car?
There's wear indicators on the tensioner, to show if the belt is stretched.
Don't be a cheapskate and look for a crap belt. Go to the dealer and get an OEM belt. I hope I don't need to explain myself here and show you why
Originally Posted by Asura,Nov 3 2005, 11:45 AM
Probably just doing preventative maintenance. Guessing they do stretch with age and the rubber becomes more brittle.
Also, I thought it was a given that I was going to get an OEM belt, I was just wondering if there's any place online I can get it rather than pay double and buy it from the dealer.
I was only asking about the drive belt because I recently purchased my S2K and it says in the manual that it should be inspected every 2 years, and since my car is a 2002 and it's almost 06 I figured it's time to change it, I didn't know there are indicators.
