replacing drive shaft
Im going to replace the propeller shaft but have been doing some reading on the site that the 6mm hex box are not easy to deal with. Has anyone figured out a good to remove these. I dont have very many resources such as dremel or heat.
I found that that Sears sells long allen wrenches that work much better than a hex socket. There isn't much clearance for the ratchet making it insert at an angle. The keys I bought are about ~7" long. For the install a 3/8" drive beam-type torque wrench works pretty well with the allen socket.
Does the driveshaft have to be aligned when you put it on? or can it go in any way (as long as the front and back are in the correct directions)
I ask because on the clutch install DIY, it mentions for you to mark the driveshaft position (in relation to the tranny and diff), what happens when you put on a new driveshaft (not from your car)
Originally Posted by SOHCmyDOHC,Sep 25 2007, 08:21 AM
There are marks you still match up. IIRC match the white marks for new driveshafts.
Originally Posted by lude9285,Sep 25 2007, 08:56 AM
but what if im installing a used driveshaft? i dont think there will be any marks on it but i will check it out when it arrives
