Replacing front shocks
Old May 3, 2001 | 01:43 AM
Luis's Avatar
Does anyone know why the lower arm ball joint must be separated from the nuckle to replace the front shocks? This is a hassle for me, as it requires a special tool. All I want is to adjust the base of my Mugen shocks.
Can I do it without separating the lower arm ball joint?
Old May 3, 2001 | 03:11 AM
Scott @ King Motorsports's Avatar
Luis-
To remove the front shocks, simply un-bolt the upper A arm from the chassis and swing it around to access the shock.
Very simple procedure..
Good Luck!
Scott
Old May 3, 2001 | 03:24 AM
cdelena's Avatar
I was wondering the same thing. I remembered this exchange but found no detail. Maybe we need to ask RandyP. Does anyone have a comment on this procedure, especially getting it back together?
Originally posted by RandyP
Originally posted by Gregg Lee
Be sure to be prepared to separate the ball joint on the front suspension to get the shock out.
When I took the front shock out, I took out the two bolts that connect the ball joint to the knuckle rather than separate the ball joint. Also, the swaybar ends interfered with removal of the shock because of the brake line support so I had to disconnect the bar.
[QUOTE]Originally posted by Gregg Lee
[B]Clever.
Old May 3, 2001 | 06:46 AM
Luis's Avatar
Originally posted by Scott @ King Motorsports
Luis-
Good Luck!
Scott
Actually, I don't need to fully remove the shock. Just release the lower attachment to be able to thread the shock base to adjust ride height.
Can I do it without the special tool?
Old May 3, 2001 | 10:59 AM
Luis's Avatar
According to the dealer the suspension will not lower without disconnecting the ball joint. He offered to lend me the Honda special tool required to do this, so I may try my hand at setting the suspension over the weekend.
Old May 3, 2001 | 01:07 PM
Luis-
Remove the two bolts that hold the upper A arm. The suspension droops and you can screw the base of the shock up or down very easily...
Give it a shot!
Cheers!
Scott
Old May 3, 2001 | 01:56 PM
RandyP's Avatar
The lower arm ball joint connects to the knuckle by two bolts with a torque setting of 64 N-m or 47 ft-lb. This will allow you to lower the lower control arm enough to adjust the shocks. The service manual does say to remove the ball joint instead, but this method worked fine for me.
Old May 3, 2001 | 04:35 PM
Luis's Avatar
ok. Several ways to skin a cat, I suppose. Just curious why would Honda document what appears to be the hardest way.
Quick question for Scott, or other experts: how important is it to load weight into the suspension before torquing nuts and bolts? Do you care?
Old May 3, 2001 | 04:55 PM
Luis-
It's always best to tighten all the suspension bolts down while the suspension is at ride height.
Good Luck!
Scott
Old May 4, 2001 | 04:29 PM
Luis's Avatar
Job done. Took Randyp route, although I think now I understand what Scott was suggesting. Insteading of threading the base on the shock to change ride height you can thread the shock on the base!
Just unbolt the two nuts that hold the top of the shock, let it drop so that they clear the body panel and turn the top of the shock to adjust height.
