Replacing Valve Cover Gasket
Old Jan 14, 2011 | 09:25 AM
JawKnee's Avatar
Default Replacing Valve Cover Gasket
Looks like I have a slight oil leak so I'm going to replace the valve cover gasket.
What are all of the gaskets and seals I should order/replace while I'm in there? Part numbers would be great as well. For example, do I need the spark plug tube seals too?
I found the following parts description from some site:
"Ishino Valve Cover Gasket Set
04-09 Honda S2000 2.2 F22C1 This gasket set includes 1 valve cover gasket and 5 sealing washers for the valve cover retaining bolts. Order the spark plug tube seals separately (use 4 of 12342-PCX-004) if using this gasket set. Also available is gasket set JVS-40258-US which includes the spark plug tube seals as well as the valve cover gasket and sealing washers. Valve Cover Gasket Set w/ spark plug seals This gasket set includes 1 valve cover gasket and 5 sealing washers for the valve cover retaining bolts. Order the spark plug tube seals separately (use 4 of 12342-PCX-004) if using this gasket set. Also available is gasket set JVS-40258-US which includes the spark plug tube seals as well as the valve cover gasket and sealing washer"
Old Jan 14, 2011 | 11:03 AM
CapoArgentino's Avatar
Banned
Only buy HONDA parts not generic brands. Go here:
http://www.hondaautomotiveparts.com/auto/j...NDER+HEAD+COVER
Item 001. Part# 12040-PCX-305
Old Jan 14, 2011 | 11:19 AM
JawKnee's Avatar
I would definitely only buy Honda parts
So all I need to order is (1) 12040-PCX-035?
No need for spark plug tube seals or are they included in the set above?
Thanks!
Old Jan 14, 2011 | 11:57 AM
Banned
Yes, sorry. Also get the tube seals and cover bolt seals as well.
Old Jan 14, 2011 | 12:43 PM
JawKnee's Avatar
Any chance you know the part numbers for those too?
Old Jan 14, 2011 | 01:20 PM
Banned
They should be on that same page, on that same list. Let me know if not I'll try to find them for you.
Old Jan 14, 2011 | 02:26 PM
JawKnee's Avatar
You're right; my bad for not looking closely.
So this is what I have down (so far):
(1) "GASKET SET, HEAD COVER " p/n: 12040-PCX-305
(4) "SEAL, SPARK PLUG TUBE (NOK) " p/n: 12342-PCX-004
Is that the complete list of parts I need for the job?
Old Jan 14, 2011 | 03:01 PM
Banned
That should be it. The gasket set already includes the valve cover bolt seals
Old Jan 14, 2011 | 04:01 PM
SgtB's Avatar
You may be able to pull the cover and clean and grease the seals and seat with silicone grease. That usually does the trick.
Old Jan 14, 2011 | 10:52 PM
funkemonke's Avatar
be careful when putting the valve cover back on. pay attention to the rear cam gears as it cuts the gasket.
