Resurfacing Rotors
Old Jun 28, 2005 | 05:30 AM
SolReborn's Avatar
Default Resurfacing Rotors
1) do you need to resurface everytime u change your brakepads?
2) can you resurface slotted or drilled rotors?
Old Jun 28, 2005 | 07:02 AM
steven975's Avatar
1. no. it depends on the condition
2. i believe so
Old Jun 28, 2005 | 07:16 AM
SolReborn's Avatar
Ok, thanks. I was changing my brakepads, and a friend of mine told me i needed to resurface the rotors everytime i do so...
I guess it should be ok
Old Jun 28, 2005 | 07:56 AM
DouglaS2000's Avatar
He probably meant that you should just lightly sand/scuff the surface of the rotors when changing out the pads. Helps the pads seat/bed in more quickly.
Old Jun 28, 2005 | 03:03 PM
Slows2k's Avatar
Some shops will not replace pads without resurfacing the rotors. If they are not causing a vibration under braking don't worry about it.
Resurfacing slotted or drilled rotors can be a little difficult due to the lathes bit breaking contact with the rotor surface . In some cases the bit will break, making resurfacing difficult. Some shops don't like the added hassle of damaged bits and restarting the resurfacing procedure every time the bit has to be replaced.
It would also be wise to contact the rotor manufacturer to see if they reccomend resurfacing a slotted/drilled rotor.
thebleeding
33
Mar 10, 2009 10:41 PM
-DOZER-
Jul 5, 2007 05:17 PM
B.Money
Apr 16, 2007 09:56 AM
LordMagnet
Oct 2, 2004 10:14 AM
Pinky
Dec 5, 2001 08:47 PM
