Reused Head gasket, Compression Results.
Old Aug 13, 2010 | 05:26 PM
JuicedS2K's Avatar
Default Reused Head gasket, Compression Results.
Before i replaced my i replaced my my stock HG with a IP 3mm i had 240 psi on all cylinders. Just realizing after all these hours spent in my garage the past 2 days your not supposed to reuse head gaskets. Now I'm seeing 210,210,235,210.
Basically, DONT REUSE A HEAD GASKET.
Old Aug 13, 2010 | 05:48 PM
essi1553's Avatar
I'm really sorry to say this buddy, but yea man thats one gasket you always should replace if you have the chance.
Sorry to be a dick, but that really really really blows.
Old Aug 13, 2010 | 05:53 PM
ChefJ's Avatar
those numbers aren't that bad. Just sayin.
Old Aug 13, 2010 | 05:56 PM
JuicedS2K's Avatar
i know, but the thing is i dont know if it will get worse. I dont care how much power the care makes to be honest.
Do you think i should just drive it around and see if it gets worse ?
Old Aug 13, 2010 | 06:09 PM
JuicedS2K's Avatar
Is it possible there can be a lot of coolant leaking into cylinder with those numbers of
235,210,210,210 ???
Old Aug 13, 2010 | 11:06 PM
H22toF20's Avatar
Those numbers seem fine. The spread in numbers is what you need to look for, unless they're stupid low.
But yeah, NEVER reuse a head gasket.
Old Aug 14, 2010 | 07:37 AM
JuicedS2K's Avatar
Just checked the #'s again more precisely. They are 220,220,230,220. I don't know why but i feel like thats so terrible and i'm down like 20 hp or something.
Old Aug 14, 2010 | 03:36 PM
camuman's Avatar
thats not awful, and honestly if your selling teh car i wouldnt worry about it tahts for sure.
Old Aug 14, 2010 | 04:21 PM
ChefJ's Avatar
I know alot of guys that would love those compression numbers. I wouldn't worry about as long as you know that you torqued it properly and had a good bead of hondabond. It probably set pretty good.
Old Aug 14, 2010 | 06:43 PM
AusS2000's Avatar
Of course your compression is lower with a 3mm head gasket. That's what it is designed for.
Just get it nicely tuned and enjoy it.
