Reverse bolt on tranny?
Old Dec 22, 2006 | 05:04 AM
GDM S2K's Avatar
Default Reverse bolt on tranny?
well hears my situation. the shop that is putting my motor in says that on the tranny a bolt was missing for the car to go in reverse or something of that nature. he now says he has to take it to a tranny shop to see what the issue is. does anyone have a clue about what bolt or nut im talking about. if so is there a certain way to get it in?
Old Dec 22, 2006 | 06:03 AM
fperra's Avatar
You need to get a better description of what the shop is talking about if you expect to get an any help here. But I'll take a guess that your shop screwed something up removing the engine and they have come up with some cockamamy story about a bolt was missing.
Old Dec 22, 2006 | 06:09 AM
GDM S2K's Avatar
I honestly have no idea what there talking about it kinda doesnt make sense to me. they said there is a bolt that hooks on the the tranny for reverse.... Ive looked at all the scimatics in the book and cant find what they are talking about...
Old Dec 22, 2006 | 06:19 AM
MikeyCB's Avatar
I'd be in there with a diagram asking them to point out the part.
Sounds like they're trying to pass the buck for something they did wrong.
Old Dec 22, 2006 | 01:28 PM
dbzerk's Avatar
An internal bolt? Then it could be anything...
Old Dec 22, 2006 | 02:25 PM
Slows2k's Avatar
There is a bolt for the reverse idler gear shaft that is bolted through the case. If someone where to remove this bolt the reverse idler shaft could turn and the only way to get the bolt back in is to open the transmission case, so you can turn the idler shaft and it's holder.
Old Dec 22, 2006 | 03:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I agree on mechanic's error.
Old Dec 22, 2006 | 04:57 PM
Boofster's Avatar
The bolts on the gear on the diff are usually reverse. At least they were on a b-series LSD I installed.
Old Dec 22, 2006 | 06:06 PM
Slows2k's Avatar
A B series trans has a differential inside the same case, not so on a S2k. The bolts that hold the ring gear on are completely unrelated to the gear inside the trans that is used for reverse.
Old Dec 22, 2006 | 09:22 PM
Empedocles99's Avatar
Maybe they just don't know to push the shifter in to engage reverse?
