Rounded the differential fill plug...
I'm guessing that you rounded off the fill bolt by using a 24mm wrench correct ?, if so try a proper sized 23mm wrench you might be able to get it to budge if it can still be saved. Then order a new fill bolt.
A large sized vice grip should work if you give it a good snap by hitting it bluntly with a hammer.
Originally Posted by GoP-Demon' timestamp='1402867778' post='23204335
I was also very stupid and drained it first.
What should my next steps be? Bring it to a shop for them to try and get it out? Vice grips?
FYI he stripped his differential drain bolt not the motor oil drain bolt. I wouldn't recommend the Fumoto for the diff. Aside from the clearance issues, the bottom of the diff is also used as a jacking point.
Get a vise on there and knock it loose. Space is very tight, so it's going to be a pita.
Also google, twist sockets. They're made to remove rounded bolts.
Originally Posted by cosmomiller' timestamp='1402884385' post='23204525
[quote name='GoP-Demon' timestamp='1402867778' post='23204335']
[/quote]
Whoops, you are correct! I missed that, sorry.
