RPM stayed at 6k even when in neutral
Old May 12, 2005 | 05:49 PM
iwantyellows2k's Avatar
Default RPM stayed at 6k even when in neutral
So i just got a K&N filter and installed in the other day. Today as I was driving, I decide to gun it. When I tried to put it in neutral, the RPM would not go lower than 6k. When I put it back into gear, the RPM would increase without my foot on the pedal. Anyone know what's going on? I wouldn't think changing the filter would have something to do with it.
Help!
Old May 12, 2005 | 06:03 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dam...first thing I'd do is make sure your throttle plate isn't sticking, or the cable isn't getting hung up on something.
Old May 12, 2005 | 06:08 PM
thanks...i checked and the throttle looks ok..hmm
Old May 12, 2005 | 06:19 PM
twelv's Avatar
Your clutch might be slipping.
Old May 12, 2005 | 06:26 PM
Billman250's Avatar
Top Answer: 1
If your description is correct, your clutch is NOT slipping.
Old May 12, 2005 | 07:01 PM
thanks everyone, i think i figured it out...throttle needed to be lubed up with some wd40
Old May 13, 2005 | 09:37 AM
SolReborn's Avatar
would that be the cold engine rev limiter coming into play?
Old May 13, 2005 | 03:27 PM
JDMwhore's Avatar
Vacuum hose could have poped off
Old May 13, 2005 | 06:43 PM
WarrenW's Avatar
That was exactly what I was thinking. There are several hoses attached to the intake air box and the "snorkal".
Warren
Old May 13, 2005 | 07:05 PM
FF2Skip's Avatar
Guys, he figured it out. So basically, billman was right... the throttle was stuck.
