running with O2 sensor removed?
Old May 8, 2003 | 09:52 AM
CRX 18's Avatar
Default running with O2 sensor removed?
Other than throwing a check engine light, will the car run fine at wide open throttle with the O2 sensor removed? I ask because I want to temporarily (an hour or so for VAFC tuning purposes) put in an inline wideband O2 sensor hooked to a computer(FJO) with out adding another bung. Thanks for the help.
Old May 8, 2003 | 10:01 AM
Hobbyholic's Avatar
It should
Old May 9, 2003 | 09:18 PM
CRX 18's Avatar
Any more specific replies (not that I don't appreciate the first one)? Will the car run full strength at wide open throttle allowing me to tune a VAFC? Thanks.
Old May 9, 2003 | 09:46 PM
Wesmaster's Avatar
Primary O2 = No, it should NOT run normally - at least not during normal driving (non-WOT). In popular theory at WOT it would run off the map not off the Primary O2 readings.
Secondary O2 - Yes, it will drive normally.
Old May 11, 2003 | 02:34 PM
Tugz_S2K's Avatar
Banned
It will run like CRAP....the ECU falls into what is called "limp" mode which is a preset set of parameters that are there just to keep the engine running. Any engine load at WOT, or prolonged use WILL damage your engine.....
I dont even think VTEC will engage in "limp" mode
your choice...Good Luck
Old May 11, 2003 | 02:56 PM
cdelena's Avatar
I am in the market for a secondary O2 sensor if anyone wants to unload one. PM me with a reasonable rice.
Old May 11, 2003 | 03:45 PM
ChrisD's Avatar
White, wheat or wild?
Old May 11, 2003 | 04:07 PM
Wesmaster's Avatar
The Rice is Right!
booost02
Mar 3, 2014 08:41 PM
liquidgsr
Mar 31, 2013 09:14 AM
JuicedS2K
Jan 5, 2011 05:59 AM
Ap2spoonf20c
Oct 14, 2010 11:10 AM
OC_
May 28, 2006 08:24 AM
