Running in oil
Old Apr 16, 2006 | 07:05 AM
Bassy's Avatar
Thumbs up Running in oil
Hey,
I've got a s2k which hasn't been driven for 3 years and has only done 12 miles, this has been regulary started up, but not driven.
I don't really want to use this oil as i am now going to start using the car,
Obviously i don't want to use the old oil so i will replace all the lubricants but i will need to get the oil supplement (breaking in oil)
Where do i get this from in the uk?
which oil is best 10w 30?
any information would be much appreciated
Old Apr 16, 2006 | 08:49 AM
xviper's Avatar
You should ask this in the UK forum. It's too specific to be asked here. You just need a high moly concentrate supplement and that's only if you feel you must. A few people have dumped their factory oil early and just started using off the shelf oil without any problems.
Since this is pretty much still a "new" car and it's new to you, you should find the owner's manual and read it. It will answer many of the questions you have or that may come up. It will also tell you that 10W30 or 5W40 is the recommended oil.
Old Apr 16, 2006 | 08:56 AM
Tugz_S2K's Avatar
Banned
I would just keep the oil that is in there now as it is still good.
Run it up to 1-2000kms and then change it out to any 10W30 oil.
I did this on my S2k, changing the factory fill out at 2000kms to Valvoline All Climate 10W30. Then changed it again at 5000kms.
When I hit 9000kms I changed out to Amsoil 10W30. Car has 30,000kms and even after hard lapping or high rpm street driving i have zero oil consumption, not to mention a healthy dyno at 200whp.
Good luck
Old Apr 16, 2006 | 09:39 AM
S2kracka's Avatar
Three year old semi-used oil is not still good!
Old Apr 16, 2006 | 10:02 AM
Tugz_S2K's Avatar
Banned
So does oil go bad? Tell me what is motor oil's shelf life...
Old Apr 16, 2006 | 12:07 PM
WarrenW's Avatar
According to Motorweek's Pat Goss, oil that has been sitting in an engine for a long time should be changed BEFORE starting it up. He said that the acids in the oil can eat away at the bearings. I'm not saying I take everything he says as gospel, but he has more experience in the automotive industry than I have.
Warren
Old Apr 16, 2006 | 12:39 PM
S2kracka's Avatar
Oil's shelf-life in the sealed bottle is quite a long time, but once its been used in an engine conventional is good for around 6 months and synthetic about a year.
Old Apr 16, 2006 | 07:21 PM
RACER's Avatar
Bassy
Guest
S2KI User #: 57184
S2KI Age: 0 yrs 8 days
PPD Average: 0.2
Owner
"2001" Silverstone/Red
Shrewsbury
hasn't been driven for "3 years"
only done "12 miles"
Let's see...um, MY01, driven 12 miles in 3 years, it is now the year 2006...
It just doesn't add up
Old Apr 17, 2006 | 07:41 AM
Wisconsin S2k's Avatar
wow... just wow. oil oxidizes. that's why in your service manual it says xxxx miles OR xxx months. That oil is nowhere NEAR "good".
you changed your oil WAY too soon than is necessary. waste of money and resources. the factory fill can be left in for 3750-7500 miles.
You should not have put synthetic in until at least 7500 miles. You put in synthetic too early. The effects of this may be nothing at all, or premature engine failure. chances are you'll be ok, but none the less....
Old Apr 17, 2006 | 12:09 PM
Tugz_S2K's Avatar
Banned
[QUOTE]wow... just wow.
