Rust in engine bay
Old Feb 14, 2015 | 09:37 AM
vtaky0's Avatar
Default Rust in engine bay
Does anyone have any advice re: removing this steel bar from the front of my 2002 AP1?
The bar is rusting bad and the screws won't budge. I've removed one of them using an impact driver but the other 4 are solid.
How can I get them out? I'm not concerned about damage as I've got a replacement bar and 5 screws ready to go on. Would you drill them out?
Edit: my pic is pointing to the rubber seal. I'm talking about the steel bar below it.
Old Feb 14, 2015 | 10:25 AM
vtaky0's Avatar
Getting bored of it now. I'm just going to chisel off the screw heads, lift the bar off and get some mole grips on what's left of the screw.
Old Feb 14, 2015 | 10:28 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Vise grips will grab them no problem. Spray first, work back and forth, you don't want to break them off.
Old Feb 14, 2015 | 10:30 AM
vtaky0's Avatar
You're a much more patient man than me Billman.
I'll give it a try when it gets light.
Old Feb 14, 2015 | 10:50 AM
Billman250's Avatar
Top Answer: 1
Don't chisel, the metal beam the screws thread into is very thin and you will bend it up easily.
Old Feb 14, 2015 | 10:53 AM
vtaky0's Avatar
Well I was hitting it quite hard with the impact driver so I'm guessing the damage has already been done.
I am replacing the bar though. Or did you mean something beneath may get damaged?
Old Feb 14, 2015 | 05:56 PM
alphalanos's Avatar
i managed to get some stuck ones out by using a screwdrive that fit perfectly and putting all my weight on it while turning. otherwise I would do what billman says just vice grip em out
Old Feb 15, 2015 | 10:45 AM
zeroptzero's Avatar
Must be some crazy rust on those bolts, they are such low torque bolts I would never expect them to be so hard to remove.
Old Feb 15, 2015 | 02:09 PM
vtaky0's Avatar
The rust is bad, hence replacing the bar rather than wire brushing it and repainting.
Old Feb 15, 2015 | 06:05 PM
NoMoreCivicsPlease's Avatar
Haha I just did this to put my cooling plate on... I wasn't reusing the bar so when I finally got one of the end bolts off I pulled the metal bar up toward the next bolt and wiggled it around while using the driver, took a few minutes each bolt
