s2000 cd009 speed sensor and reverse
Old Jun 4, 2020 | 01:59 PM
boosteds2ksammy's Avatar
Default s2000 cd009 speed sensor and reverse
currently have my cd009 setup going in. looked for a write up for the speed sensor wiring and reverse.. does anyone have a write up ?
Old Jun 24, 2020 | 04:40 AM
treimche's Avatar
Reverse is easy, you can just connect the 2 wires from your OEM reverse switch to the one on the CD009 trans. Polarity doesn't matter. If you don't have the Nissan connector you'll want to get one.
For the speedometer, you'll have to buy a converter of some sort. The 350z speedometer is driven off of their ABS computer, so there is no speed sensor on the transmission. I am currently trying to configure a Dakota Digital SGI-100BT to drive the S2000 speedometer. Once I get it set up and working properly I can share how it was done. Currently I have the left rear ABS sensor as my signal into the Dakota Digital box, but haven't figured out the settings to make the S2000 cluster display the proper speed yet.
Old Jun 24, 2020 | 05:39 PM
awesome. i will be here waiting for update
Old Jun 24, 2020 | 06:39 PM
treimche's Avatar
I got the speedometer working and calibrated today! I'll take a screenshot of the settings I used in the Dakota Digital setup app tomorrow, and type out how I have everything wired in. It should be pretty easy now that I have it all sorted out.
Old Jun 30, 2020 | 11:50 AM
status on diy? car is currently on jackstand
Old Jun 30, 2020 | 05:29 PM
treimche's Avatar
Sorry I've been really busy. My car is also on jack stands again. Thinking I'll just make a new thread with this info so it can help other people too.
Old Jun 30, 2020 | 07:09 PM
treimche's Avatar
@boosteds2ksammy here you go: https://www.s2ki.com/forums/s2000-un.../#post24746221
zakiu
Mar 18, 2018 02:07 AM
K_iju
Mar 15, 2018 01:19 PM
regray1
Feb 20, 2017 05:11 PM
windhund116
Jun 28, 2016 11:34 AM
