S2000 Crash
Old Mar 21, 2017 | 06:22 AM
Hitt Flow's Avatar
Unhappy S2000 Crash
Hey, so today i crashed my s2000 into a ditch. Im very sad about it but that aside, do any of you think the engine will still work? i have to wait till tomorrow untill i can take a look at it.
here are some pictures
Old Mar 21, 2017 | 06:25 AM
windhund116's Avatar
Man! Glad you are okay.
Old Mar 21, 2017 | 06:26 AM
Hitt Flow's Avatar
thanks
Old Mar 21, 2017 | 07:02 AM
Mister Jew's Avatar
Holy ****....if the engine didn't shut off it's prob toast
Old Mar 21, 2017 | 07:08 AM
darcyw's Avatar
I'd tow it home, change the oil- how much water is in the oil? remove the spark plugs- how much water is in the cylinders- don't try to start it- it may have water in one of the cylinders- that's bad and will hydrolock the engine if it hasn't already.
glad you can swim
darcy
Old Mar 21, 2017 | 07:44 AM
s2000Junky's Avatar
Jesus man! Glad you are ok, that was a pretty nasty one!
Yeah echoing what's been said, don't try and turn over the engine until you completely drain the oil and make sure there is no water in the cylinders. You probably should remove the pan to insure this. Pull the plugs as well. See if they are wet.
Old Mar 21, 2017 | 08:08 AM
NNY S2k's Avatar
That must have been a hell of a ride! Glad you're OK
Levi
Old Mar 21, 2017 | 08:23 AM
Car Analogy's Avatar
If this isn't a troll post, wow! So many ways that could have ended really badly for you (killing you and not just your motor).
It all comes down to if engine ran while intake was submerged. If that happened, it probably hydrolocked and engine destroyed. If it didn't happen, chances are engine only has minor damage.
But you must, MUST! Follow the advice given, remove plugs before you even try to crank motor over, even by hand, and drain oil and change it.
Old Mar 21, 2017 | 08:33 AM
ipeefreely's Avatar
The love for the s2000 is strong here. lol
Old Mar 21, 2017 | 08:52 AM
s2000Junky's Avatar
Stronger then some of the dips that drive them
