s2000 Rear toe arm (bumpsteer kit) problem
Old Apr 23, 2013 | 01:31 PM
Real talk's Avatar
Default s2000 Rear toe arm (bumpsteer kit) problem
So i've been having this problem with my rear right clunking when turning slowly I jacked my rear up the right rear has play side to side and the clunking from the side to side is coming from the toe arm (bumpsteer arm) my mechanic said it was broken internally has anyone had problems with these? They are cheap ebay ones but will i have to buy new ones or is there a way to fix?
Old Apr 24, 2013 | 06:43 AM
Stratocaster's Avatar
You should be able to replace the joint.
Old Apr 24, 2013 | 09:49 AM
jsenclosure's Avatar
they cannot break internally...there is a tie rod on each end (1 is reverse thread) and they are replaceable. somewhere in my build thread are mcmaster-carr part numbers for the ones on the t1r kit, which i would bet are the same as yours.
User 11317
Oct 29, 2008 04:06 AM
jyeung528
Apr 18, 2007 08:15 AM
JohnnyRingo
Aug 16, 2005 06:52 PM
Ludedude
Jul 9, 2004 07:54 AM
