S2K axles same size?
Old Aug 13, 2011 | 05:01 PM
WarrenW's Avatar
Default S2K axles same size?
Aren't the S2K axles the exact same size or is one shorter than the other? I thought you could switch them from left to right. Am I missing something?
Old Aug 13, 2011 | 05:57 PM
Stratocaster's Avatar
They are different sizes. One is longer then the other. You can swap the cups from side to side to change the thrust surfaces
Old Aug 15, 2011 | 08:20 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Left side, or drivers side in the USA, is shorter.
The inner buckets that bolt to the dif with the 6 bolts are the same and can be removed and swaped with each other.
radiantm3
Jan 22, 2016 07:11 AM
Sunnybank
Mar 25, 2010 07:31 AM
PR84
Apr 17, 2008 01:38 PM
Pepe
Oct 24, 2000 01:11 PM
