S2k dies at idle -- video inside
Old May 10, 2013 | 03:05 PM
Chris Stack's Avatar
Default S2k dies at idle -- video inside
2003 S2000, 101k miles, mechanically stock.
Just started happening today; doesn't do it when the car is cold, but gets intermittently worse as time goes on. Car will sometimes hang at 2k rom when coasting, and the. Drop to about 400rpm and just die ( :40s into video).
IAC cleaning?
PCV valve?
MAP?
Other ideas?
http://m.youtube.com/watch?v=egeN6U06ADA&feature=plcp
Old May 10, 2013 | 03:17 PM
xviper's Avatar
IAC cleaning?
PCV valve?
MAP?
Other ideas?
Don't coast. Leave the clutch up as long as possible. Downshift as you slow down and when you're in second or first, wait till rpm is well below idle before pushing the clutch down to stop.
Old May 10, 2013 | 03:43 PM
apme123's Avatar
take the IAC valve apart, clean it, then do the relearn idle procedure
Old May 10, 2013 | 06:17 PM
jl56tc's Avatar
take some break cleaner to that IAC and check your throttle cable
Old May 10, 2013 | 07:43 PM
dantediss's Avatar
Map whack and ecu relearn.
Theres diy on the site for both procedures
Old May 11, 2013 | 02:27 PM
Cleaned IAC, did MAP Whack, and reset ECU. Fixed the problem and car idles smoother now than ever. Thanks guys
Old May 11, 2013 | 07:19 PM
apme123's Avatar
nice to hear
noahw526
Feb 17, 2018 08:18 PM
Mark355
Jan 17, 2018 02:36 PM
Soviet
Jun 6, 2016 06:02 AM
Kyushin
Nov 26, 2011 03:39 AM
cpl_allen
Oct 23, 2010 07:13 PM
