s2k not starting
Old Jun 3, 2006 | 08:08 AM
tomh's Avatar
Default s2k not starting
its been very hot here in omaha the last couple days and for some reason my car will not start until the sun goes down and the temp cools off. any ideas? is my car nocturnal all of the sudden? i can hear the fuel pump kick on. the starter's turning it just wont kick over.
Old Jun 3, 2006 | 10:36 AM
jeggy's Avatar
is the engine cranking at all? does it turn over? i dont understand your last sentence. "kick over"? is the starter spinning the engine or is it just freewheeling?
first thing that pops into my head due to your heat is the PGM FI main relay overheating.
Old Jun 3, 2006 | 12:33 PM
xviper's Avatar
If the starter is turning, then it IS "kicking over". Or do you really mean the engine is not being turned by the starter motor? Or do you mean it IS being turned but just not "firing up"?
Old Jun 5, 2006 | 11:57 AM
tomh's Avatar
its being turned just not firing up
Old Jun 5, 2006 | 01:54 PM
xviper's Avatar
Anytime an engine will turn but not fire, you need to look at fuel, ignition and air.
Fuel - since it's hot, you may have a vapor lock. You may also have a bad fuel pump. When you key the ignition to ON, do you initially hear the fuel pump spool up? This should happen the first couple of seconds after you key it ON.
Ignition - this would involve getting spark from the plugs and getting it at the right time (timing). You'd have to take one out and ground it and crank the engine and watch for spark.
Air - is enough air going in and coming out. How's the air filter look? Did someone plug your exhaust tips?
Old Jun 5, 2006 | 06:23 PM
tomh's Avatar
ok first off when the temp outside cools down the car runs fine. fuel pump works, spark is fine, air filter fine.
i have the comptech supercharger on it. i dont really know if that would make any difference since it runs fine early and late in the day just not when its sizzlin hot out.
confused yet, i am
Old Jun 5, 2006 | 07:16 PM
xviper's Avatar
You chose now to tell us this little tidbit?
Before I type another suggestion, what else is there about your car you haven't told us?
Old Jun 5, 2006 | 08:56 PM
tomh's Avatar
stupid, i know sorry
i dont think there is anything else i forgot to tell you that would make a difference
Old Jun 6, 2006 | 09:01 AM
Wisconsin S2k's Avatar
please list your mods
Old Jun 6, 2006 | 05:20 PM
tomh's Avatar
comptech supercharger kit, neuspeed exhaust, vtec controller, dc header, besides that just suspension mods
