s2k's running like crap
Old Mar 28, 2010 | 09:15 AM
~blacks2k~'s Avatar
Did you tighten your throttle body cable after you did the cleaning by any chance?? My car had very similar symptoms and I couldn't figure out what it was, but I realized I had overtightened the throttle body cable a bit when i was doing the adjustment.
Also, if not check to see if your cable is too loose. Having a cable that is either too loose or too tight can cause similar symptoms.
Old Mar 28, 2010 | 10:36 AM
Kirpich's Avatar
^Worth checking, it's free. Doubt it would cause rich condition, though.
However, you may have 'overcleaned' the throttle body and the TPS sensor is now toast in the first half of range of motion. ECU can't tell what position your throttle is at, therefore it dumps a bunch of fuel in. And it runs crappy.
Search for an Omni Throttle Position Sensor. There is a relatively cheap fix out there, ~$140.
Before you do any of that, though, check the TPS. hook up an ohmmeter to it, and move it really really slowly, while monitoring the ohms. they should not jump at all.
Good luck and let us know for sure!
Old Mar 28, 2010 | 11:30 PM
SUPERAnimal's Avatar
Sounds like a vacuum leak. Take some brake clean and spray it around the throttle body while the engine is running. If the idle changes, then you probably have a vacuum leak.
Old Mar 29, 2010 | 05:20 AM
iamthestig's Avatar
cool, thanks for the advice guys, ill check the tps when i can get ahold of an ohmmeter. and the same for the thottle body when i can get some brake cleaner.
Old Mar 29, 2010 | 05:38 AM
bronxbomber252's Avatar
Originally Posted by stretch1386,Mar 28 2010, 08:19 AM
What octane rating is it cos you guys have different stuff to us over there right? I always run mine on Shell v-power 99 octane or if i cant get that theres a few stations do 97. I could just be a dodgy plug thats causing you the problems. Either go for NGK laser iridium or Denso iridium, they are far better than anything else.
You should invest in a few mods - filter/exhaust etc, made the world of difference to mine
You guys use a different rating system. your 97-99 would rate 91-93 using our system but it is the same gas/octane.
s2tommi
Dec 19, 2018 11:33 AM
RedSunS2K
Jun 11, 2011 12:33 PM
s2k_aristo
Jun 7, 2009 08:20 PM
slanguage
Jun 30, 2005 01:03 PM
lauralippay
Jun 29, 2005 01:44 AM
