Is it safe to put the car in neutral cruizing down
On my way home everyday, there's this long stretch on the highway that is downhill. I usually cruise down that part at about 60-70 mph on Neutral. I figure i'm saving a little gas, but is it safe to do that??
You're not saving any real amount of gas, in fact you're using more by letting it idle (assuming a richer idle condition). If you take your foot off the gas completely and just coast in gear (a higher gear at that), you will use barely any gas at all.
I don't think leaving it in neutral has any detrimental effects on anything either.
The real safety aspect here is, if the car is in neutral, and you have to react to a bad situation ahead (meaning, you have to clutch in, put the car in gear, clutch out, apply gas) you would have been that much more ahead by already having the proper gear engaged and ready to go. It's scary to think about how many people do this with automatic transmissions. :shudder:
Beyond all of this is the fact that you may save, what, $0.00006 for every time that you do this procedure. That adds up to approximately $0 at the end of the year.
Originally Posted by nzaizar,Dec 16 2004, 04:24 PM
I don't see how it could be a bad thing
Coasting in nuetral limits your contol over your automobile.
Originally Posted by webguy330i,Dec 16 2004, 04:55 PM
What ever happened to people learning how to heel-toe a proper downshift, or simply revmatching to ensure that proper gear selection for your speed?
I slip the car into neutral and coast up to stop signs, but not stop lights. The difference being that the stop light might change and then I would be out of gear, but I'm pretty sure the stop sign isn't going to change to a green "go" sign.
Originally Posted by webguy330i,Dec 16 2004, 07:55 PM
What ever happened to people learning how to heel-toe a proper downshift, .....
And no, you shouldn't cruise in neutral - safety. I cannot comment on the mechanical aspect.
Added: I know the importance of not cramming the car into a gear that it is not prepared for.
